How to use 16f877A instead of 18F452 in LedMatrix
ledmatrix.dsn
hi, There was the problem in my computer... And , I was interesting with it...
sorry, i can't understand you...
but, there isn't standart DOT and it can change their pins...
if there is the datasheet you can use it... if there is not,
you can use multimeter...
again sorry.:cry:
isamoung edaboard
HI ilker_32 I AM FROM CHILE SOUTH AMERICA AND I JUST PROGRAM IN ASSEMBLER. YOUR MATRIX WAS VERY WONDERFULL.
YOU CAN USE THE RS232 PORT???:?::?:
CANT YOU POST THE DSN FILE I HAVE PROTEUS 7.5 TOO
I VERY THANK FOR YOU
GOOD BYE FROM CHILE
MY NAME IS MIGUEL VALDIVIA:arrow::arrow::arrow:
74hc595 16f877
Hi Miguel. Thank you very much.
i'm using the Proteus 7.5 sp3. And, i gave link for the Proteus 7.5 sp3. (download)
How you are taking one error?
And, when you take, write the error here.
for the RS232,
you can use virtual terminal of the windows.
is it Ok,
take care of your self.
and,
you visit CHILE for me. That place is appearing nice.
16f877a led matrix project
thank ilker 32 ,but I just wrote to congratulate you
your matrix is very wonderfull , i want to know if program this matrix across
to rs232 port.remember i program assembler basically.cant you post the dsn file,
i have proteus 7.5 in my computer
thanks and write you soon
pbp2.50
i have anothrer question for you, waht is your pic basic compiler????
thanks and i`ll see you soon
school clock project 18f452
Hi ilker 32. i have gone through your posts, though i have not looked into your design but your ccs c coding fascinated me as i'm learning CCS C. I hope you will be disposed when need be. You are already doing great with your English. I hope you understand me. My regards to Sofier.
project 18f452
Eğer bana DSN kimse bunu denemek için dosya göndermek teºekkür ilker_32 çok teºekkür ediyorum
hi from chile
you understood what I wrote
just google ¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡
Added after 13 minutes:
but your led matrix was done in C language
or not
hi from chile
expinsives hous in the india
i'm thanking to everyone...
for that, i put the MCSP.
@porotot, which language are you useing?
please, correct my wrong writings.
example:
no : Eğer bana DSN kimse bunu denemek için dosya göndermek teºekkür ilker_32 çok teºekkür ediyorum
yes : .DSN uzantılı dosyayı deneyebilmem için bana gönderebilirmisiniz. Teºekkür ederim.
yes : .DSN uzantılı dosya üzerinde deneme yapmak istiyorum. Onu bana gönderebilirmisiniz. Teºekkür ediyorum.
you can download DSN file from here:
(use the Proteus 6.9, 7.0, 7.1, 7.2, 7.4, 7.5)
  • sofie_1242.rar
how to use 18f452
thanks very much
i am using assembler and a few of basic
but i am not a perfect programer ok
I can understand what you write a lot
bie
from chile
[/GVideo][/youtube]
To ilker_32
Ben 8 * 32 yapmaya çalışıyorum matris 74hc595 ile nokta. Do u nasıl 74hc595 bağlamak için biliyorum (pin 11, 12, 14 pic16f628A) için?
Nasıl sağdan sola kaydırma mesaj kodlama için gerekir. I like Sadece küçük bir kod .... EDABOARD "HOŞGELDİNİZ iletiyi görmek için" istedi
@supra_56,
ilker_ekener@msn.com
perhaps, i can be helper to you...
hello everyone..could you please help me? I'm a graduating computer engineering student..our design project is about led matrix..It will be 2 rows of 12 8x8 led matrices..if anybody would be sooooo good to help me..please send me a schematic for the led matrices and also a program..i don't know how I will program it using assembly language in MPLAB IDE..the pic is PIC16F877a..thanks
How to use 16f877A instade of 18F452 in LedMatrix
please telle me how i send message via rs232
is dont work
pic16F887
I have No problem With Compiling .. i Compiled the Code successfully
I tried Your New Code
long s1_char_size=23;
char s1[23];
const char   msg_default[23] = "1234567890"; // 10+13=23
But Also the Same Message Appears After 59 Second
Also the first Code have the same problem After 27 Second
long s1_char_size=26;
char s1[26];
const char   msg_default[26] = "sofie & ilker";
Try to run the Project for 5 minites .. If this message didn't Appear with You .. then the problem My Be in MY Computer
Is the Problem In Your Name ("sofie & ilker") Or What :D:D Just joke
pic16F887 with 8Mhz
I got code working.
I'm Using pic16F887 with 8Mhz, using mikroC pro.
Here is code:
#define PIN_ST_CP PORTC.F2 //PIN_C2 // RCLK ----> Pin 12 ST_CP
#define PIN_SH_CP PORTC.F3 //PIN_C3 // SRCLK ---> Pin 11 SH_CP
#define PIN_SER_IN PORTC.F5 //PIN_C5 // SER -----> Pin 14
//***********************columns of hc595**********************************
#define clock PORTB.F0 // PIN_B0 // RCLK ----> Pin 12 ST_CP
#define latch PORTB.F2 // PIN_B2 // SRCLK ---> Pin 11 SH_CP
#define data PORTB.F1 // PIN_B1 // SER -----> Pin 14
char s1[26];
long i;
void HC595_OUT_satir(unsigned char send_data)
unsigned char bit_mask;
for (bit_mask=1; bit_mask ;bit_mask <<=1)
if((send_data & bit_mask))
data=0;
else
data=1;
clock=0;
delay_us(20);
clock=1;
latch=0;
delay_us(50);
latch=1;
const char msg_default[30] = "HAPPY BIRTHDAY SUPRA";
const char ascii4[96][6] = {
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 }, // sp
{ 0x00, 0x00, 0x00, 0x2f, 0x00, 0x00 }, // !
{ 0x00, 0x00, 0x07, 0x00, 0x07, 0x00 }, // "
{ 0x00, 0x14, 0x7f, 0x14, 0x7f, 0x14 }, // #
{ 0x00, 0x24, 0x2a, 0x7f, 0x2a, 0x12 }, // $
{ 0x00, 0x23, 0x13, 0x08, 0x64, 0x62 }, // %
{ 0x00, 0x36, 0x49, 0x55, 0x22, 0x50 }, // &
{ 0x00, 0x00, 0x05, 0x03, 0x00, 0x00 }, // '
{ 0x00, 0x00, 0x1c, 0x22, 0x41, 0x00 }, // (
{ 0x00, 0x00, 0x41, 0x22, 0x1c, 0x00 }, // )
{ 0x00, 0x14, 0x08, 0x3E, 0x08, 0x14 }, // *
{ 0x00, 0x08, 0x08, 0x3E, 0x08, 0x08 }, // +
{ 0x00, 0x00, 0x00, 0x50, 0x30, 0x00 }, // ,
{ 0x00, 0x10, 0x10, 0x10, 0x10, 0x10 }, // -
{ 0x00, 0x00, 0x60, 0x60, 0x00, 0x00 }, // .
{ 0x00, 0x20, 0x10, 0x08, 0x04, 0x02 }, // /
{ 0x00, 0x3E, 0x51, 0x49, 0x45, 0x3E }, // 0
{ 0x00, 0x00, 0x42, 0x7F, 0x40, 0x00 }, // 1
{ 0x00, 0x42, 0x61, 0x51, 0x49, 0x46 }, // 2
{ 0x00, 0x21, 0x41, 0x45, 0x4B, 0x31 }, // 3
{ 0x00, 0x18, 0x14, 0x12, 0x7F, 0x10 }, // 4
{ 0x00, 0x27, 0x45, 0x45, 0x45, 0x39 }, // 5
{ 0x00, 0x3C, 0x4A, 0x49, 0x49, 0x30 }, // 6
{ 0x00, 0x01, 0x71, 0x09, 0x05, 0x03 }, // 7
{ 0x00, 0x36, 0x49, 0x49, 0x49, 0x36 }, // 8
{ 0x00, 0x06, 0x49, 0x49, 0x29, 0x1E }, // 9
{ 0x00, 0x00, 0x36, 0x36, 0x00, 0x00 }, // :
{ 0x00, 0x00, 0x56, 0x36, 0x00, 0x00 }, // ;
{ 0x00, 0x08, 0x14, 0x22, 0x41, 0x00 }, // <
{ 0x00, 0x14, 0x14, 0x14, 0x14, 0x14 }, // =
{ 0x00, 0x00, 0x41, 0x22, 0x14, 0x08 }, // >
{ 0x00, 0x02, 0x01, 0x51, 0x09, 0x06 }, // ?
{ 0x00, 0x32, 0x49, 0x59, 0x51, 0x3E }, // @
{ 0x00, 0x7E, 0x11, 0x11, 0x11, 0x7E }, // A
{ 0x00, 0x7F, 0x49, 0x49, 0x49, 0x36 }, // B
{ 0x00, 0x3E, 0x41, 0x41, 0x41, 0x22 }, // C
{ 0x00, 0x7F, 0x41, 0x41, 0x22, 0x1C }, // D
{ 0x00, 0x7F, 0x49, 0x49, 0x49, 0x41 }, // E
{ 0x00, 0x7F, 0x09, 0x09, 0x09, 0x01 }, // F
{ 0x00, 0x3E, 0x41, 0x49, 0x49, 0x7A }, // G
{ 0x00, 0x7F, 0x08, 0x08, 0x08, 0x7F }, // H
{ 0x00, 0x00, 0x41, 0x7F, 0x41, 0x00 }, // I
{ 0x00, 0x20, 0x40, 0x41, 0x3F, 0x01 }, // J
{ 0x00, 0x7F, 0x08, 0x14, 0x22, 0x41 }, // K
{ 0x00, 0x7F, 0x40, 0x40, 0x40, 0x40 }, // L
{ 0x00, 0x7F, 0x02, 0x0C, 0x02, 0x7F }, // M
{ 0x00, 0x7F, 0x04, 0x08, 0x10, 0x7F }, // N
{ 0x00, 0x3E, 0x41, 0x41, 0x41, 0x3E }, // O
{ 0x00, 0x7F, 0x09, 0x09, 0x09, 0x06 }, // P
{ 0x00, 0x3E, 0x41, 0x51, 0x21, 0x5E }, // Q
{ 0x00, 0x7F, 0x09, 0x19, 0x29, 0x46 }, // R
{ 0x00, 0x46, 0x49, 0x49, 0x49, 0x31 }, // S
{ 0x00, 0x01, 0x01, 0x7F, 0x01, 0x01 }, // T
{ 0x00, 0x3F, 0x40, 0x40, 0x40, 0x3F }, // U
{ 0x00, 0x1F, 0x20, 0x40, 0x20, 0x1F }, // V
{ 0x00, 0x3F, 0x40, 0x38, 0x40, 0x3F }, // W
{ 0x00, 0x63, 0x14, 0x08, 0x14, 0x63 }, // X
{ 0x00, 0x07, 0x08, 0x70, 0x08, 0x07 }, // Y
{ 0x00, 0x61, 0x51, 0x49, 0x45, 0x43 }, // Z
{ 0x00, 0x00, 0x7F, 0x41, 0x41, 0x00 }, // [
{ 0x00, 0x02, 0x04, 0x08, 0x10, 0x20 }, // back slash
{ 0x00, 0x00, 0x41, 0x41, 0x7f, 0x00 }, // ]
{ 0x00, 0x04, 0x02, 0x01, 0x02, 0x04 }, // ^
{ 0x00, 0x40, 0x40, 0x40, 0x40, 0x40 }, // _
{ 0x00, 0x00, 0x01, 0x02, 0x04, 0x00 }, // '
{ 0x00, 0x20, 0x54, 0x54, 0x54, 0x78 }, // a
{ 0x00, 0x7F, 0x48, 0x44, 0x44, 0x38 }, // b
{ 0x00, 0x38, 0x44, 0x44, 0x44, 0x20 }, // c
{ 0x00, 0x38, 0x44, 0x44, 0x48, 0x7F }, // d
{ 0x00, 0x38, 0x54, 0x54, 0x54, 0x18 }, // e
{ 0x00, 0x08, 0x7E, 0x09, 0x01, 0x02 }, // f
{ 0x00, 0x0C, 0x52, 0x52, 0x52, 0x3E }, // g
{ 0x00, 0x7F, 0x08, 0x04, 0x04, 0x78 }, // h
{ 0x00, 0x00, 0x44, 0x7D, 0x40, 0x00 }, // i
{ 0x00, 0x20, 0x40, 0x44, 0x3D, 0x00 }, // j
{ 0x00, 0x7F, 0x10, 0x28, 0x44, 0x00 }, // k
{ 0x00, 0x00, 0x41, 0x7F, 0x40, 0x00 }, // l
{ 0x00, 0x7C, 0x04, 0x18, 0x04, 0x78 }, // m
{ 0x00, 0x7C, 0x08, 0x04, 0x04, 0x78 }, // n
{ 0x00, 0x38, 0x44, 0x44, 0x44, 0x38 }, // o
{ 0x00, 0x7C, 0x14, 0x14, 0x14, 0x08 }, // p
{ 0x00, 0x08, 0x14, 0x14, 0x18, 0x7C }, // q
{ 0x00, 0x7C, 0x08, 0x04, 0x04, 0x08 }, // r
{ 0x00, 0x48, 0x54, 0x54, 0x54, 0x20 }, // s
{ 0x00, 0x04, 0x3F, 0x44, 0x40, 0x20 }, // t
{ 0x00, 0x3C, 0x40, 0x40, 0x20, 0x7C }, // u
{ 0x00, 0x1C, 0x20, 0x40, 0x20, 0x1C }, // v
{ 0x00, 0x3C, 0x40, 0x30, 0x40, 0x3C }, // w
{ 0x00, 0x44, 0x28, 0x10, 0x28, 0x44 }, // x
{ 0x00, 0x0C, 0x50, 0x50, 0x50, 0x3C }, // y
{ 0x00, 0x44, 0x64, 0x54, 0x4C, 0x44 }, // z
{ 0x00, 0x00, 0x08, 0x36, 0x41, 0x00 }, // {
{ 0x00, 0x00, 0x00, 0x7f, 0x00, 0x00 }, // |
{ 0x00, 0x00, 0x41, 0x36, 0x08, 0x00 }, // }
{ 0x00, 0x04, 0x02, 0x04, 0x08, 0x04 }, // ~
{ 0x00, 0x00, 0x00, 0x36, 0x00, 0x00 } // ¦
void main(){
int char_index;
int col_index;
int x = 0;
int delaycount;
unsigned int startposition;
ANSEL=0;
ANSELH=0;
TRISB=0;
TRISC=0x40;
TRISD=0;
HC595_OUT_satir(0);
PORTC=0;
startposition = 0;
for(i=0; i<7; i++)
s1 = msg_default;
for(i=0; i<sizeof(msg_default); i++)
s1 = msg_default;
delay_ms(100);
while (1)
delaycount=4; //-------> acontrol scanning speed here .
while (delaycount)
col_index = startposition %6;
char_index = startposition /6;
if (char_index >= sizeof(s1))
startposition = 0;
char_index = 0;
col_index = 0;
x = s1[char_index];
// 74HC595 ler suruluyor
PIN_SH_CP=0;
PIN_ST_CP=0;
PIN_SER_IN=0;
PIN_SH_CP=1;
delay_us(1000);
PIN_SH_CP=0;
PIN_SER_IN=1;
for (i=0;i<7;i++) // 80 We use one column
PIN_ST_CP=1;
delay_us(200);
PIN_ST_CP=0;
delay_us(1000);
PIN_SH_CP=1;
delay_us(1000);
PIN_SH_CP=0;
if (col_index == 5)
col_index = 0;
char_index++;
char_index = 0;
x = s1[char_index];
else
if ( x < 32)
HC595_OUT_satir(0);
else if( x < 128)
HC595_OUT_satir(ascii4[x-32][col_index]);
col_index++;
delay_us(1000); //brightness
HC595_OUT_satir(0);
delaycount--;
startposition++;
Re: 16f877a dot ledmatrix 8x8
8 minute for you :D
AND...
I am not trusting to the Proteus....
sir is your row here is cathode and your column is anode? in your row what demultiplexer you used? and what specific components to be added in the row? and also in the column.. what is there to sink the current? because i want to implement in real hardware.. and i want to know whats the components of this project.t :)
Both r using 74HC595. On the top is connected to portB is column and rest is connected to portC is rows.
so whats your row? anode or cathode? you have full schematics on this? including the transistors and resistors you used?
Using same schematic that ilker_32 posted on this forum or the one u posted it. I used common cathode(usually i have bi-colour dot matrix). No need to used transistor or resistor. 74HC595 can handle up to 20 or 25 ma.
Fortunately, i used resistors for rows. Also can be used unl2003. Can u do same schematic as u already posted it?
you have common cathode? so that means your row is cathode?
you can download my project here..
https://www.edaboard.com/threads/199151/
im using 74hc154 in my rows.. and i dont know what transistors to use to sink up my rows current.. i have 7x40 led matrix which is 7 cathode rows and 40 anode columns.. in my columns, i am using 74hc595 and what resistor or transistor should i add up to sink my columns? need help on a real hardware design.. because i want to implement this with less errors.. :) thanks!
