omelette
Junior Member level 1
Hi. Channel 1 inexplicably stopped working on this 'scope - in use for hours, working perfectly, turned off & switched on the following day, no channel 1!
Channel 2 still work fine in all respects when connected to the test-waveform, whereas channel 1 displays either a flat trace, or a blank screen as if voltage is off-scale (depends on voltage setting selected). I also notice that I can't adjust the trace's base-position on screen - the trace does not follow the 'GND' symbol when it is moved up/down, it's vertical position on screen remaining the same.
I have had it apart and although both channels have identical circuitry, the voltages on I.C pins on the faulty channel are all over the place - for instance, one SMD AT&T chip (UB1202AM) has almost -12V on several pins whereas the working channel's chip voltages are mere fractions of a volt! Despite this, these chip temperatures are within a degree Celsius of one another, so no apparent overheating. Finally, a continuity-check on what appear to be supply decoupling capacitors on the other side of the PCB but directly under this chip buzz through as being almost shorts. I have even removed the I.C. to see if it was the culprit - it wasn't!
Seeing as this PCB has at least 3-layers, without a circuit diagram, this is an exercise in futility! Worse, I have failed to even find a pin-out of the chip I mentioned, which most list as "obsolete stock", let alone a complete circuit diagram. I have found HP's "User & Service manual" which is a bit of a joke as there's no circuit diagram and the cure for every system-board fault listed is to replace the system-board!!!
Excuse the long-winded post, but can anyone either provide me with a circuit diagram for this scope or else suggest a possible cause of the problem. Thanks.
