scorrpeio
Full Member level 5
Hi...
I have written code for timer0 in which everytime TMR0 overflows...it plays buzzer.
However, I didnt use ISR. I used this...
This is working fine.
However, I want to achieve same, using Timer Interrupt.
I tried with this...
I had activated the Global and TIMER0 inetrrupts. But, execution never went into isr loop. I have never used isr in pic. I guess, I could not write it properly. Can anyone let me know, why does it not work? (I have gone through different threads on this site to write the above routine.)
void EnableTimer (void)
unsigned int Cnt_15min = 2;
TRISCbits.TRISC2 = 0; //Set BUZZER pin as o/p pin
PORTCbits.RC2 = 0; // Keep BUZZER OFF
TMR0L = 0x00;
T0CON = 0x07; // prescalar of 1:256; internal clock; 16 bit mode
// Timer disabled
// INTCONbits.GIE = 1; //Enable Global Interrupt
// INTCONbits.TMR0IE = 1;//Enable Timer0 Interrupt
while( Cnt_15min )
T0CONbits.TMR0ON = 1; //Start Timer0
while (INTCONbits.TMR0IF == 0 );
// PORTB = 0b00000000;
INTCONbits.TMR0IF = 0;
Cnt_15min--;
T0CONbits.TMR0ON = 0; //Disable Timer
PORTCbits.RC2 = 1; //BUZZER ON
PORTCbits.RC2 = 0;
GetTemperatureValue();
#pragma code low_vector = 0x18
void high_ISR (void)
_asm goto timer0_isr _endasm
#pragma code
#pragma interrupt timer0_isr
void timer0_isr(void)
INTCONbits.TMR0IE = 0; //Disable Timer 0 Interrupt
INTCONbits.TMR0IF = 0; //Clear Timer 0 Interrupt Flag
PORTB = 0b00000000;
