you can make 2 layer pcb at home but but you can't do through hole plating in small cost, but bga you need through hole plating
how old are you?
I have seen a few examples of 2-layer PCBs for BGA. It can work, if only a small part of BGA signal pins is utilized in the design and not too many separate supply voltages are involved. Usual BGA-PCBs are rather using 6 (and more) than 4 layers.
I effectively don't see a method to make multilayer PCBs in a DIY process.
Regarding PCB through-plating (for double sided PCB), it's not a primarly a problem of galvanic copper deposition. This is the most easy part. The problem is the preceeding chemical copper deposition, which is complex. multi-step process and also the applying an etch resist to the drilled and through plated board. I wasn't motivated to watch a 15 minute video, do you know, how to achieve these critical steps?
a thin chemical copper (currentless) must be deposited first, then the galvanic coating can be applied.what did you mean "preceeding
More exactly chemical copper a two step process.
- a seed deposition, typically silver
- a "reductive" copper solution
It's not easy. Actually I liked to know, if the author of the Youtube film suggests a more simple throughplating process. I doubt, he can.I did not understand anything
hii .........
can i make a 2 layer pcb for bga? or it's must be multi layer
