zhipeng
![Member level 1](/styles/images/ranks/dlevel1.gif)
Say, in the top level verilog netlist, it instantiates four instances of the same module DECODER.
After RTLCompiler has done elaborate and synthesis, they becomes instances of four differently-named modules, DECODER, DECODER_1667, DECODER_1668, and DECODER_1669.
How do I prevent the same module been renamed and re-synthesized to different implementations?
Later in hierarchical P&R, if I make one of the four copies as master partition, what is the command to make the other three into clones of the master partition?
