Autocad DXF generation in Altium 09
hasitri
Junior Member level 1
To generate a DXF/DWG out of Pcbdoc, I am using File -> Save As and generating a DXF. Unfortunately I am unable to generate any polygon fills in the PCB. Means, in the generated DXF, I can see the boundary line of a fill but not the complete solid fill.
Any thoughts?
Thanks,
Trinath
Got that. Thanks loosemoose!!!
But, what is the logic behind this?
I think this is simply the way Altium exports it.
The file size in Altium is smaller for the solid polygon.
