which IR sensor you are using..
and i m using 8051 with freq 11.0592mhzTSOP 1738 IR sensor i m using
It will function at 38khz frequency that can be generated in uc itself.
view the link below:
http://www.datasheetcatalog.org/datasheets/208/301092_DS.pdf
To familiarize yourself with the NEC protocol, please check this useful link. You should have a thorough knowledge of the protocol before coding.
SB-Projects: IR remote control: NEC protocol
i knows the NEC protocol
if u have the proper code for reading remot entered code and displaying that code on lcd using 8051 controller , please pass to me . urgent
