nschutten
Member level 3
![Member level 3](/styles/images/ranks/dlevel3.gif)
I am very interested in starting some SystemC (I am actually from a HW background, but want to gain some further system understanding). I downloaded the SystemC lib from Home - Open SystemC Initiative (OSCI) and compiled it under VC++ Express 10. When I now try to run the following simple example code (I also enabled RTTI and added systemc.lib to the project, and added the src directory to the include path, per the suggestions of the user guide):
#include "systemc.h"
SC_MODULE (hello_world) {
SC_CTOR (hello_world) {
// Nothing in constructor
void say_hello() {
cout << "Hello World.\n";
int sc_main(int argc, char* argv[]) {
hello_world hello("HELLO");
hello.say_hello();
return(0);
I get the following error messages: can anyone please help me out here?? Many thanks in advance!!
1>------ Build started: Project: HelloWorld, Configuration: Debug Win32 ------
1> HelloWorld.cpp
1>c:\systemc\src\sysc\datatypes\int\sc_nbutils.h(85): warning C4996: 'sprintf': This function or variable may be unsafe. Consider using sprintf_s instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. See online help for details.
1> c:\program files\microsoft visual studio 10.0\vc\include\stdio.h(371) : see declaration of 'sprintf'
1>msvcprtd.lib(MSVCP100D.dll) : error LNK2005: "public: class std::locale::facet * __thiscall std::locale::facet::_Decref(void)" (?_Decref@facet@locale@std@@QAEPAV123@XZ) already defined in SystemC.lib(sc_report_handler.obj)
1>libcpmtd.lib(ios.obj) : error LNK2005: "private: static void __cdecl std::ios_base::_Ios_base_dtor(class std::ios_base *)" (?_Ios_base_dtor@ios_base@std@@CAXPAV12@@Z) already defined in msvcprtd.lib(MSVCP100D.dll)
1>libcpmtd.lib(ios.obj) : error LNK2005: "public: static void __cdecl std::ios_base::_Addstd(class std::ios_base *)" (?_Addstd@ios_base@std@@SAXPAV12@@Z) already defined in msvcprtd.lib(MSVCP100D.dll)
1>libcpmtd.lib(locale0.obj) : error LNK2005: "private: static void __cdecl std::locale::facet::_Facet_Register(class std::locale::facet *)" (?_Facet_Register@facet@locale@std@@CAXPAV123@@Z) already defined in msvcprtd.lib(locale0_implib.obj)
1>libcpmtd.lib(locale0.obj) : error LNK2005: "private: static class std::locale::_Locimp * __cdecl std::locale::_Getgloballocale(void)" (?_Getgloballocale@locale@std@@CAPAV_Locimp@12@XZ) already defined in msvcprtd.lib(MSVCP100D.dll)
1>libcpmtd.lib(locale0.obj) : error LNK2005: "private: static class std::locale::_Locimp * __cdecl std::locale::_Init(void)" (?_Init@locale@std@@CAPAV_Locimp@12@XZ) already defined in msvcprtd.lib(MSVCP100D.dll)
1>libcpmtd.lib(locale0.obj) : error LNK2005: "public: static void __cdecl std::_Locinfo::_Locinfo_ctor(class std::_Locinfo *,char const *)" (?_Locinfo_ctor@_Locinfo@std@@SAXPAV12@PBD@Z) already defined in msvcprtd.lib(MSVCP100D.dll)
1>libcpmtd.lib(locale0.obj) : error LNK2005: "public: static void __cdecl std::_Locinfo::_Locinfo_dtor(class std::_Locinfo *)" (?_Locinfo_dtor@_Locinfo@std@@SAXPAV12@@Z) already defined in msvcprtd.lib(MSVCP100D.dll)
1>libcpmtd.lib(xlock.obj) : error LNK2005: "public: __thiscall std::_Lockit::_Lockit(int)" (??0_Lockit@std@@QAE@H@Z) already defined in msvcprtd.lib(MSVCP100D.dll)
1>libcpmtd.lib(xlock.obj) : error LNK2005: "public: __thiscall std::_Lockit::~_Lockit(void)" (??1_Lockit@std@@QAE@XZ) already defined in msvcprtd.lib(MSVCP100D.dll)
1>LIBCMTD.lib(_file.obj) : error LNK2005: __lock_file already defined in MSVCRTD.lib(MSVCR100D.dll)
1>LIBCMTD.lib(_file.obj) : error LNK2005: __unlock_file already defined in MSVCRTD.lib(MSVCR100D.dll)
1>LIBCMTD.lib(setlocal.obj) : error LNK2005: __configthreadlocale already defined in MSVCRTD.lib(MSVCR100D.dll)
1>LIBCMTD.lib(dbgheap.obj) : error LNK2005: __free_dbg already defined in MSVCRTD.lib(MSVCR100D.dll)
1>LIBCMTD.lib(dbgheap.obj) : error LNK2005: __CrtSetCheckCount already defined in MSVCRTD.lib(MSVCR100D.dll)
1>LIBCMTD.lib(crt0dat.obj) : error LNK2005: _exit already defined in MSVCRTD.lib(MSVCR100D.dll)
1>LIBCMTD.lib(crt0dat.obj) : error LNK2005: __exit already defined in MSVCRTD.lib(MSVCR100D.dll)
1>LIBCMTD.lib(crt0dat.obj) : error LNK2005: __cexit already defined in MSVCRTD.lib(MSVCR100D.dll)
1>LIBCMTD.lib(crt0dat.obj) : error LNK2005: __amsg_exit already defined in MSVCRTD.lib(MSVCR100D.dll)
1>LIBCMTD.lib(crt0dat.obj) : error LNK2005: __initterm_e already defined in MSVCRTD.lib(MSVCR100D.dll)
1>LIBCMTD.lib(fflush.obj) : error LNK2005: _fflush already defined in MSVCRTD.lib(MSVCR100D.dll)
1>LIBCMTD.lib(dbghook.obj) : error LNK2005: __crt_debugger_hook already defined in MSVCRTD.lib(MSVCR100D.dll)
1>LIBCMTD.lib(sprintf.obj) : error LNK2005: _sprintf already defined in MSVCRTD.lib(MSVCR100D.dll)
1>LIBCMTD.lib(crt0init.obj) : error LNK2005: ___xi_a already defined in MSVCRTD.lib(cinitexe.obj)
1>LIBCMTD.lib(crt0init.obj) : error LNK2005: ___xi_z already defined in MSVCRTD.lib(cinitexe.obj)
1>LIBCMTD.lib(crt0init.obj) : error LNK2005: ___xc_a already defined in MSVCRTD.lib(cinitexe.obj)
1>LIBCMTD.lib(crt0init.obj) : error LNK2005: ___xc_z already defined in MSVCRTD.lib(cinitexe.obj)
1>LIBCMTD.lib(hooks.obj) : error LNK2005: "void __cdecl terminate(void)" (?terminate@@YAXXZ) already defined in MSVCRTD.lib(MSVCR100D.dll)
1>LIBCMTD.lib(invarg.obj) : error LNK2005: __invalid_parameter already defined in MSVCRTD.lib(MSVCR100D.dll)
1>LIBCMTD.lib(invarg.obj) : error LNK2005: __invoke_watson already defined in MSVCRTD.lib(MSVCR100D.dll)
1>LIBCMTD.lib(mlock.obj) : error LNK2005: __lock already defined in MSVCRTD.lib(MSVCR100D.dll)
1>LIBCMTD.lib(mlock.obj) : error LNK2005: __unlock already defined in MSVCRTD.lib(MSVCR100D.dll)
1>LIBCMTD.lib(winxfltr.obj) : error LNK2005: __XcptFilter already defined in MSVCRTD.lib(MSVCR100D.dll)
1>LIBCMTD.lib(atox.obj) : error LNK2005: _atoi already defined in MSVCRTD.lib(MSVCR100D.dll)
1>LIBCMTD.lib(crt0.obj) : error LNK2005: _mainCRTStartup already defined in MSVCRTD.lib(crtexe.obj)
1>LIBCMTD.lib(errmode.obj) : error LNK2005: ___set_app_type already defined in MSVCRTD.lib(MSVCR100D.dll)
1>LIBCMTD.lib(dbgrptw.obj) : error LNK2005: __CrtDbgReportW already defined in MSVCRTD.lib(MSVCR100D.dll)
1>LIBCMTD.lib(printf.obj) : error LNK2005: _printf already defined in MSVCRTD.lib(MSVCR100D.dll)
1>LINK : warning LNK4098: defaultlib 'MSVCRTD' conflicts with use of other libs; use /NODEFAULTLIB:library
1>LINK : warning LNK4098: defaultlib 'LIBCMTD' conflicts with use of other libs; use /NODEFAULTLIB:library
1>C:\SystemC\PRJ\HelloWorld\Debug\HelloWorld.exe : fatal error LNK1169: one or more multiply defined symbols found
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
void say_hello() {
hello.say_hello();
return(0);
1> HelloWorld.cpp
