Increasing bandwidth 2 stage opamp cmos
elpajuo
Junior Member level 2
I am designing a 2 stage differential cascode opamp with 2 outputs
The circuit and gain are attached
How can I increase the bandwith of the circuit or operate at higher frequencies
hello,
You should know that we always Gain Bandwidth Product is constant, if you increase the gain will decrease the bandwidth and vice versa. Use a simple cascode amplifier or increase the output current. The bandwidth is proportional to Iout.
Hi
I can not see how large is your bandwidth. I have designed fully diff 2 stages op amp 1.8v has 500Mhz bandwidth. 61db gain and 64 degree phase margin. I use standard 2 stage op amp (no cascade). I think you can improve your bandwidth from 800Mhz to 1ghz
Hi
Can you show us the design of this circuit?
---------- Post added at 14:38 ---------- Previous post was at 14:27 ----------
As slamnas said the relation between the gain and the bandwidth is Inverse proportion, and i saw it when i designed 2 stage op amp with cmos.
