sole_developer
Junior Member level 3
I have though about making a power supply (Variable), switch for either 12V or 13V (some chips need 12V!)........The LM317.bmp LM317 structure, the one I have designed is in the pdf....Could you please help me with your experiance whether or not what I have designed will work...
THanks in advance!
(PS: I used the voltage calculator on LM317 Voltage Calculator - Electric Circuit)
PS: the '+13/+12' pin will be the output based on position of the switch PWR.
View attachment POWER BOARD.pdf
THanks in advance!
