ASK shown in the diagram is actually OOK(on-off keying). Generate input sq.wave. Then Generate a carrier(cosine wave) with a higher frequency as compared to sq.wave.. just multiply both u will get ASK..
For ASK input square wave should have levels 0 and 1.. Change the levels to -1 and +1.. follow the similar procedure to obtain PSK.. For FSK u have to generate two carriers(sinusoidal and triangular as in the diagram).. Using an if loop switch the output depending on whether the input is 1 or 0..
Hello Ill post my code here, would u mind having a look at it please
thanks
This is for ASK
% Generating a input square wave
x1 = 0pi/100)10*pi);
y1 = square(x1);
A = plot(x1,y1);
figure(1),A,title( 'Square wave');xlabel('x'); ylabel('y');ylim([0,1]);grid;
% Generating a carrier(cosine wave) with a higher frequency as compared to sq.wave
f=0.8
t = 0pi/100)10*pi);
y2 = cos(2*pi*f*t);
figure(2),B = plot(t,y2),title( 'Sine wave');xlabel('x'); ylabel('y');ylim([-2,2]); xlim([0,35]);grid;
