allennlowaton
Full Member level 5
Good day fellows,
I planned to implement a 5 to 10 ohm resistor on chip.
I will be using the 0.35 micron process.
Is this reasonable and attainable?
The current that will flow through it will 20-25mA.
Thank you.
---------- Post added at 08:00 ---------- Previous post was at 07:58 ----------
please mention also the available material that I can utilized from the 0.35u process.
---------- Post added at 08:07 ---------- Previous post was at 08:00 ----------
don't be confused. the resistor is not the only device in the chip, it's just one of the components in the LED driver circuit.
Thank you.
