do you have any literature, i am trying to implement it in cadence. the whole adc should drive a 50ohm resistor where should the 50 ohm resistor connected
I don't think the ADC should drive a 50ohm resistor. Maybe, you mean that the ADC should have a 50ohm input termination...
Just do a search on the IEEExplore website or google for "pipeline ADC" and you will find tons of references.
1- Regarding your digital, you need to design the clock generator circuit (non-overlapping clock), digital correction logic and the MDAC ( comparator + some gates + ...)
2- About literature, you can find theory in the following thesis (available in google):
(a) Design for Reliability of Low-voltage, Switched-capacitor Circuits by
Andrew Masami Abo
(b) A POWER OPTIMIZED PIPELINED ANALOG-TO-DIGITAL CONVERTER DESIGN IN DEEP SUB-MICRON CMOS TECHNOLOGY - Chang-Hyuk Cho
(c) A 10-bit 25Msps Pipeline ADC for Companding Baseband Processing in Wireless Application - Shenjie Wang
