ObedMiramontes1
I designed a voltage regulator with that regulates 19 volts and outputs 13.5volts.
I did this by using a 5.1 Zener diode and TL081 op-amp and a npn BJT... I connected the zener diode to the op-amp and by calculating the resistor values adjusted the gain of the op-amp to get my output of 13.5. The thing is that i need more current out of the regulator... so far, i only got a few milliamps and i need at least 1.5A...
Any ideas?
This voltage regulator is going to be connected to a charge regulator to charge a 12 Volt 20Ah battery!
Any ideas?
