help the PowerPC440 and the FPGA application
lahrach
Full Member level 3
Full Member level 3
Hi friends;
I ask if it is possible can I use the embedded controller PowerPC440 to control an application on trhe FPGA.
example :
PPC440 to control an FFT implimented on the FPGA
if it is possible can you help me by sending to me your seggestions and tips
regards
Yes. You can place a design on the powerpc bus and from there control anything. There are many examples in the Xilinx EDK folder that show how to integrate a hardware design and the powerpc. Using bus reads/writes, you can control anything. You are limited of course to the bus speed.
Good luck
Hi Chops211
thank you for this answer
have you examples,
regards
