shampoo
Newbie level 3
![Newbie level 3](/styles/images/ranks/alevel3.gif)
Dear all
i usually use AVR for my projects, but as you all may know arm is more powerful (because it has lots of stuff about USB LAN Speed ... ) so i want to learn this, but unfortunately i can't buy any development kits i just have the software KEIL installed on our university computer ( i have complete access to the computer).
the problem is that ,the guides on the net are a lot !! when i wanted too learn AVR i used a simple book starting with a simple example of blinking led, and then when i worked more i used AVR datasheets, to understand how exactly each part works and know i feel familiar with AVR.
but you know, about ARM there's lots of datasheets, and i know learning arm is more complicated, but it would be a risk if i start any of datasheets on the net (arm.com , or atmel arm based microcontrollers like at91sam7s .. ) without consulting any experienced people.
so do you know any getting started guide which is based on using ARM (not the architecture) uses KEIL or another free software?
i want you to suggest me somewhere to start .
Thank you.
Thank you.
