storier
Newbie level 1
Dear all,
I have a verilog design is quite small (below 512FF), which is optimized for FF usage. My boss want to put it in FPGA(or something else) as cheap as possible(since the required clock rate is only 3Mhz, and only five I/O pins required). I ask some sales(lattice, altera), but I quickly found that some low-end products are no longer available. I didn't have any experience on FPGA, so I known none about all the things different between FPGA and ASIC. Did anyone has suggest FPGA for this low-end application(below $2)? Thanks a lot.
