need information about ICs
SUSHIL KAPOOR
Newbie level 5
Newbie level 5
Hi All,
I got 2 defective SMD ICs having numbering as below:
1. D 151821-0571 (this is 24 pin IC made in SO package)
2. 5P373 1411D (this is 10-pin IC used in power section of the board. )
I need the datasheet of these ICs and purchasing info (preferably in India)
Please help
thanx
What kind of IC it is please explain cearly. Beacuase if i'm google it i'm not getting any information.
I am not having the exact information. Only info that I have is:
IC D 151821-0571 ---This was used in one electronic controller module.
5P373 1411D --- This is used in the power section of a photoframe player. This seems some kind of power convertor.
I tried to search for the datasheet of these ICs but didnt find anything :(
If anyone using this or having some info , please help
5P373 1411D looks like some IC from Linear Tech. Better to enquire from their customer support if the IC is obsolete.
Umesh.
I just checked. Linear Tech have a similar part number LTC1411. But that is a kind of ADC. Also that IC is of more that 32 pins. But my required IC is of 10-pins. :(
Please look further, if possible
The part numbers are obviously house numbers and a datasheet for them is probably not available. The parts might not be available.
you can perhaps look at :idea: digikey.com
and you will certainly get it.........
Keep Smiling :D
Nikhil
