DrWhoF
Advanced Member level 1
I would like to replace non-available part UAA4000 with a microcontroller to generate Pulse-Position-Modulation.
The circuit is rather complicated and it uses 922 keypad decoder, 4066 switches, some transistors and HC154 – all to control the inputs of the UAA4000.
My plan is to use simple switches (pull-up to Vcc and switch to GND), I need only 10 of them, and to program a microcontroller to generate coded information (PPM) as if it was done by the UAA4000.
Any suggestion?
Any suggestion?
