X4ROY
Newbie level 6
i have purchased a locally made programmer and development board separately .
The programmer seems to be working as i uploaded the hex file generated from MPLAB IDE into the PIC using Micropro . it wrote " program sucessfully completed " then i read from the chip and checked it it was programmed .
the program was to blink two LEDS connected to ports RB2 and RB3 .
PROBLEM : i put the Programmed Pic into the development board then connected the +ve of the led to ports rb2 and rb3 separately for the two LEDS . next the common -ve terminal of the Leds were connected to the ground terminal , well in my development board i cant see the terminals of mclr , gnd , vcc , vdd , vss all i see is a bunch of input outports of A , B , C ,D and at the position near the power supply there are three pins reading 12V , 5V , GND now considering this pin to be ground i have connected the common negative terminal of LED to it . POWERED IT UP and nothing happens . my development board did not come with any manual so i have no clue please help ... im a beginner
i have attached the c code i wrote for this .
