i need Audio level meter layout
Marvel2025
Newbie level 3
Newbie level 3
hi all
plz i need the layout of Audio level meter that i can make it on the PCB
thanks
The circuit doesn't show a level meter, only a running LED controlled by the recorded sound.
    Marvel2025
I can give you the PCB and all the detail parts just send me your Email to me and I will send it to you
    Marvel2025
I agree with FvM, all this circuit does is sequence the LEDs, one by one. The LM386 is not the best device to use and may not be stable without a low impedance load and there is a possibility of the LEDs being damaged by reverse polarity.
    Marvel2025
thanks fvm
thanks betwixt
i need a very simple audio level meter
if u have, send it 2 me
thanks
Google for LM3914 and LM3915, they are LED bargraph drivers. The 3914 has a linear response, the 3915 is logarithmic. For audio you normally want logarithmic so the LM3915 would be best choice. The data sheets normally have schematics for audio level meters in them.
if u have, send it 2 me thanks
Sending to E-mails and private sharing will not be entertained much here. As far as possible, share anything in the open forum for benefit of all the members. Cheers
    Marvel2025
