Need help with my code for GPS
Naumanpak
Pakistan
Hi experts, need help once more..
I am trying to get data from serial pin TXD of GPS module Holux GR-89 and then display on the LCD using 8051 microcontroller.
Module works perfectly when interfaced with PC.
With your guidance, I was successfully able to interface the 16x4 LCD.
But now, I am getting dummy values displayed on LCD.
GPS(TXD)------>89c51(P3.0)RXD------>LCD(getting dummy values)
LCD displays every thing right other than the data from serial pin.
here is my code:
#include <regx51.h>
#include <lcd.h>
#define lcd_port P0
#define XTAL     11.059200
#define XDIVIDER 12.0
#define delay_1ms 164 * (XTAL/XDIVIDER)
void delay(unsigned char);
void delay_ms(unsigned int);
void SerialInit()
				TMOD = 0x20;	 // timer 1 (8 bit auto-reloed)
				TH1 = 0xFA; //to obtain 4800 baud rate
				TR1 = 1;	 //start timer
				SCON = 0x50;
 				return;
unsigned char SerialRecvChar()
				while(!RI);	 //waits till a byte is recieved
				RI = 0;
				return (SBUF);
main()
	              unsigned char ch;
			      unsigned int i=0;
			      lcd_command(0x01);
			      Lcd_Ini();
			      lcd_display('G');
			      lcd_display('P');
			      lcd_display('S');
			      lcd_display(' ');
			      lcd_display('B');
			      lcd_display('a');
			      lcd_display('s');
			      lcd_display('e');
			      lcd_display('d');
			      lcd_command(0xC2);
			      lcd_display('N');
			      lcd_display('a');
			      lcd_display('v');
			      lcd_display('i');
			      lcd_display('g');
			      lcd_display('a');
		            lcd_display('t');
			      lcd_display('i');
				lcd_display('o');
			      lcd_display('n');
				lcd_command(0x94);
			      lcd_display('*');
			      lcd_display('*');
			      lcd_display('*');
			      lcd_display('*');
				while(1)
				 		SerialInit();
						ch=SerialRecvChar();
						lcd_command(0xd0);
				                lcd_display(ch);
						lcd_command(0xd1);
				                lcd_display(ch);
						lcd_command(0xd2);
						lcd_display(ch);
						lcd_command(0xd3);
						lcd_display(ch);
						lcd_command(0xd4);
				                lcd_display(ch);
						lcd_command(0xd5);
				            lcd_display(ch);
						lcd_command(0xd6);
				                lcd_display(ch);
						lcd_command(0xd7);
				               lcd_display(ch);
						lcd_command(0xd8);
				                lcd_display(ch);
						lcd_command(0xd9);
				                lcd_display(ch);
						lcd_command(0xda);
				                lcd_display(ch);
						lcd_command(0xdb);
				                lcd_display(ch);
You may check the serial initialization routine. SCON = 0x50; should be in before start the timer (TR1 = 1; )
void SerialInit()
            SCON = 0x50;
            return;
regards
bassa
    Naumanpak
How much delay you are using in the LCD routine?
You must empty the serial buffer within 2 msec so that it will not overflow.
Also the
SerialInit();
routine should be called out side the main loop.
Also check the SMOD bit.
    Naumanpak
Check this part also
            while(RI == 0);    //waits till a byte is recieved
	     ch = SBUF
            RI = 0;
            return (ch);
SerialInit(); should be above the while as below
lcd_display('*');
	SerialInit();
            while(1)
And also did you able to display first letters which are "GPS BASED..." ?
Hope your comment after testing above
regards
bassa
    Naumanpak
AMK1971, I have tried to call SerialInit(); outside main.
and here is my lcd code
void Lcd_Ini()
                lcd_command(0x38);
                delay_ms(30);
                lcd_command(0x0c);
                delay_ms(10);
                lcd_command(0x06);
                delay_ms(10);
                lcd_command(0x01);
                delay_ms(10);
void lcd_command(unsigned char command)
                rw=0;
				delay_ms(10);
                rs=0;
				delay_ms(10);
                lcd_port=command;
                enable=1;
                enable=0;
                delay_ms(5);
void lcd_display(unsigned char display)
                rw=0;
				delay_ms(10);
                rs=1;
				delay_ms(10);
                lcd_port=display;
				enable=1;
                enable=0;
                delay_ms(1);
void delay_ms(unsigned int i)
       			for(;i!=0x00;i--)
               			delay(delay_1ms);
void delay(unsigned char j)
                for (;j!=0x00;j--)
thanks
Added after 14 minutes:
Bassa, I have tried your suggestions but still getting dummy values rather than NMEA stream.
Yes I get the other thing displayed correctly.
GPS based
navigation
thanks
Dear Nauman,
As you may have noticed by now that your lcd_Command function takes 25ms and lcd_display function takes 21ms, but you only have 2 msec time between succesive characters.
one option is to remove the unnecessary delays like below
                rw=0;
//            delay_ms(10);
                rs=0;
//            delay_ms(10);
                lcd_port=command;
                enable=1;
                enable=0;
                delay_ms(1);
                rw=0;
//            delay_ms(10);
                rs=1;
//            delay_ms(10);
                lcd_port=display;
            enable=1;
                enable=0;
                delay_ms(1);
more appropriate thing is to poll the status and check if the LCD has finished working on your command.
**broken link removed** contains a source code for AVR devices for the 4 bit interface of LCD with status checking. You can modify it for your purpose.
Also you can use a buffer to store the stream received from serial and start displaying it when the buffer is full.
    Naumanpak
Thank you AMK1971, I have removed maximum of the delay and tried to use buffer as well now but am not getting NMEA streams.
I keep getting dummy characters like this
LLLlllllplpppp
jjjvrppppppp
Jwssrprrrlllll
LLLPPPLLWk
here is a portion of main that replicates.
	  while(1)
	  lcd_display(SerialRecvChar());
And here is the lcd_display()
                rw=0;
                rs=1;
                lcd_port=display;
                enable=1;
                enable=0;
                delay_ms(1);
Suggest please.
thanks
You may try to read data (GPS) through 8051 serial interrupts
    Naumanpak
Thanks for another response Bassa,
I have tried interrupts but same problem.
I am able to receive serial data but the wrong one. Gettting dummy characters rather than receiving NMEA data.
The value read from in SBUF seems incorrect.
thanks
Added after 1 minutes:
Do you think that the problem may be with the baud rate?
Changing the baud rate changes the values on LCD.
thanks
Added after 17 minutes:
It ought to be the issue,
when I change the baud rate on pc, similar things happen.
I have tried keil baud rate generator https://www.keil.com/products/c51/baudrate.asp but things dont seem to get working.
thanks
I finally got it working!!!!!!
thank you all!
it was the baud rate that I was struggling with.
thanks again, the problem is resolved now
