vivek_p
Is the path which we get when "report_timing" command is entered in Design Compiler , the critical path of the design?
When I synthesised the design , I got data required and arrival time as 16 ns
I synthesised the design again after an addition of a latch. Then I got the "latch path" when I entered "report_timing". The data required and arrival time is 4
ns
When I checked the old path using report_timing -from ... -to I got timing as 16
Why is it so? Doesn't "report_timing" give critical path or else is it an exception when latches are synthesised?
ns
