budimanc
Newbie level 5
Hi, i had some problem with my program, when i compile its seems ok.
But when i tried simulate it in hardware simulation using proteus, the text doesnt appear. I'm using Port B as data dan Port A to control. Can you please check it.
The program is
End
[/code]
The program is
LIST P=16f877, c=100, n=55, st= OFF ; pilih tipe prosesor
include "p16f877.inc" ; sertakan file penetapan nama-nama register
Enbl equ 0
RSel equ 1
RW equ 2
RBPU equ 7
lcdram1 equ 0x80 ; alamat DDRAM baris 1
temp equ 10h
cblock 0x20
tundacch,tundac5,karcch,index
disp1:16 ; buffer tampilan brs 1
bufptr ; pointer alamat buffer tampilan
lcdram ; variabel untuk alamat DDRAM
endc
org 0x00 ; awal program reset
nop
goto start
;Rutin menginisialisasi PortA dan PortB.
InitPort:
bcf STATUS,RP1 ;
bcf STATUS,RP0 ;select bank0
clrf PORTA ;buat semua Port_A rendah
bsf STATUS,RP0 ;select bank1
movlw B'00000110' ;setel Port_A sebagai digital I/O
movwf ADCON1 ;saat power-on reset port_A ana inputs
clrf TRISA ;buat semua Port_A output
movlw B'00000000' ;PORTB all outputs
movwf TRISB ;
return
;menerbitkan tundaan 1 mdet (1000 siklus) termasuk call
tunda1ms: movlw d'199' ;
movwf tundacch ;
tnd11: nop
nop
decfsz tundacch,f ;
goto tnd11 ; lup 199*5
return
;menerbitkan tundaan 5 mdet menggunakan tunda1ms
tunda5ms:
movlw d'5' ;
movwf tundac5 ;
tnd15: call tunda1ms
decfsz tundac5,f ;
goto tnd15 ;
return ;
;menerbitkan pulsa Enable LCD
aktif_E: ;
bsf PORTA,Enbl ;bawa E ke logika 1
nop ;tunggu sesaat
bcf PORTA,Enbl ; kembalikan E ke 0
call tunda1ms ; tunggu selama 1 mdet
return
; menginisialisasi LCD
initlcd:
; modus komando
bcf PORTA,Enbl ;bawa Enable ke rendah
bcf PORTA,RSel ;pilih reg Instr, RS=0
bcf PORTA,RW ;pilih modus tulis RW=0
call tunda1ms ;beri waktu bagi kontroler LCD utk init
;Function Set
movlw 0x38
movwf PORTB
call aktif_E ; aktifkan Enable, beri waktu bagi kontroler
;Display OFF
movlw 0x08 ; kode mematikan tampilan, kursor dan kedip
movwf PORTB
;Display and Cursor ON
movlw 0x0E ; kode hidupkan tampilan & kursor tanpa kedip
movwf PORTB ; 0000 1110
call aktif_E ; aktifkan Enable dan beri waktu bagi kontroler
;Entry Mode Set
movlw 0x06 ; kode tampilan diam - kursor bergerak kanan
movwf PORTB ; 0000 0110
;Cursor/Display Shift
movlw 0x14 ; kode tampilan diam - kursor bergerak kanan
movwf PORTB ; 0001 0100
call aktif_E ; aktifkan Enable dan beri waktu kontroler
;Clear Display
movlw 0x01 ; kode untuk membersihkan tampilan
movwf PORTB ; 0001 0001
Return
;mengisi buffer tampilan dengan blank
kosongbuf
movlw D'16' ; Set up counter
movwf karcch
movf bufptr,w ; First PIC RAM address
movwf FSR ; Indexed addressing
movlw 0x20 ; kar spasi ASCII
simpan:
movwf INDF ; Store blank character in PIC RAM
decfsz karcch,f ; Done?
goto almtbrkt ; no
return ; yes
almtbrkt: incf FSR,f ; Bump FSR to next buffer space
goto simpan
; Rutin pengiriman teks dari buffer ke LCD
tampilcd:
bcf PORTA,Enbl ; E line low
bsf PORTA,RSel ; RS line low for control
call tunda1ms ; Delay
movlw D'16' ; pencacah karakter
movwf karcch
; Get display address from local variable pic_ad
movf bufptr,w ; alamat awal buffer teks
movwf FSR ;
getkar:
movf INDF,w ; ambil karakter dari buffer
movwf PORTB
call aktif_E ;kirimkan ke LCD
decfsz karcch,f ; turunkan pencacah
goto karbrkt ; sampai habis
return
karbrkt: incf FSR,f ; Bump pointer
goto getkar
; Memilih alamat DDRAM untuk baris tampilan LCD
; alamat buffer ada di variabel lcdram
baristpl:
bcf PORTA,Enbl ; aktifkan E (E= 0)
bcf PORTA,RSel ; pilih IR (RS= 0)
call tunda1ms ; tunggu 1 ms
; pilih alamat pertama baris
movf lcdram,w ; alamat dan bit komando
movwf PORTB
call aktif_E ; Pulse and delay
; pilih reg data DR
bsf PORTA,RSel ; pilih reg data (RS= 1)
return
; Subrutin membawa teks pesan dari mem program ke buffer RAM
; input: bufptr= alamat buffer
; w= offset di buffer
; local: psn1= rutin pencatu pesan dengan 0 sbg terminator
; index= variabel indeks tabel
bawapsn1:
movwf index ; atur indeks buffer
movf bufptr,w ;
addwf index,w ;
movwf FSR ; muat ke FSR
; mulai pembacaan tekes dari indeks ke 0
movlw 0 ;
movwf index ; awali index dengan 0
ambilkar: ; w digunakan sepagai penunjuk
call psn1 ; ambil karakter dari tabel
andlw 0x0ff ; Test apakah 0 (terminator)
btfsc STATUS,Z ; Test zero flag
goto endpsn1 ; End of string
; simpan karakter di w ke buffer
movwf INDF ; buffer ditunjuk FSR
incf FSR,f ; arahkan ke buffer berikut
movf index,w ; naikkan indeks dan muat ke w
addlw 1 ; untuk karakter berikutnya
movwf index ;
goto ambilkar ; ulangi
endpsn1: return
; Rutin membawa teks pesan brs-1 dari mem program ke buffer di file reg
psn1: addwf PCL,f ; ambil elemen ke-w
retlw ' '
retlw ' '
retlw ' '
retlw ' '
retlw 'E'
retlw 'm'
retlw 'b'
retlw 'e'
retlw 'd'
retlw 'd'
retlw 'e'
retlw 'd'
retlw ' '
retlw ' '
retlw ' '
retlw ' '
retlw 0
start:
call InitPort ;initialize port B
call tunda1ms
call initlcd
call tunda5ms ;beri waktu untuk lcd untuk initialisasi
; Simpan alamat awal buffer teks tampilan PIC
movlw disp1 ; alamat awal buffer teks tampilan PIC
movwf bufptr ; muat ke variabel penunjuk
;awali buffer tampilan blank
call kosongbuf ;kosongkan buffer tampilan PIC
; Bawa teks ASCII ke buffer tampilan di PIC
movlw d'1' ; Offset tampilan
call bawapsn1 ; pindahkan teks ke buffer
; Setel alamat DDRAM untuk baris-1
movlw lcdram1 ; tunjuk alamat DDRAM baris-1
movwf lcdram
call baristpl ;setel alamat DDRAM
call tampilcd ;tampilkan teks
loop: goto loop
[/code]
