rs-485 info / tutorial / drivers needed
pharos
Junior Member level 1
avrco pascal 1wire
Hello All,
I need some good tutorial/notes for RS-485 and any s/w drivers for that. Please help.
Enjoy,
:D pharos :D
485info
RS-485 is "electrical level" interface. It is half duplex. I assume you are interested in some specific protocol that uses RS485 as interface?
Tom
Hi
You have same companny that make that drivers here some link to the
interface chips datasheet:
1. sipex.
2. linear.
https://www.linear.com/prod/pft.html?product_family=interface
3. national semiconductors.
4. maxim/dallas.
Best regards. 8)
Hello Tom,
I may be wrong, but what i think is that RS-485 is a serial protocol and i need to develop some s/w drivers over that.
Thanks,
pharos
No, RS485 is not a 'protocol'. Protocol is a set of rules which determine how a connection is established, maintained and terminated. Data exchange is also part of these rules. Protocols are usually implemented by software layer.
Tom
Reactions: vs3474
    vs3474
hello, pharos.
As tom324 said, RS485 is a hardware interface not a protocol. Some people call it "protocol RS485" but it is not right.
There are a lot of protocol specification in the net. You can only choice that you need.
Can I help you? I used Modbus protocol for years.
Shematics and other **broken link removed**
Hi Pharos,
Tom324 is right about RS485 - it is just interface, not a protocol. You probable have to decide which protocol you will implement in software driver(s). I’m using Dallas “1-wire” protocol over RS485 interface to increase distance of the net.
Regards,
stroma
Hello guys,
Thanks for the information. Please give me some useful links for RS-485 tutorials. I basically want to implement a serial protocol over RS-485.
regards,
pharos
It all depends what is your application. For instance, for instrumentation using serial links (RS232, RS485 +others) you may get ready made software for free at
https://www.windmill.co.uk/rs232.html
You may also find intersting to read
https://www.ece.utexas.edu/~valvano/manual/Lab10.pdf (See also the directory .../manual/ for more documents)
The same professor, Jonathan W. Valvano, has also a software archive (written in C for MC68HC812) containing different things, including a driver for RS-485 networking:
https://www.ece.utexas.edu/~valvano/programs/
Good luck,
Ted
hey! have you already implemented your protocol?
Anyway, i recomend you to take a look at **broken link removed**
They have created SNAP, a very good protocol. It is open an free:D
    V
For RS-485 cabling guidelines, you can view the technical note **broken link removed**
jarmestor :)
PD:
I think that RS-485 is an electrical specification in many physical layer protocols (bitbus, profibus,....)
If you want protocol I use written in E-L-a-b A-V-R-c-o P-A-S-C-A-L, say it. I can also give you windows test software for this protocol.
Avra
RS485 is a standard !!
pharos said:
Hello guys,
regards,
pharos
pharos ,
RS485 is a standard , see RS485.com there yo'll find plenty of resource .
Ts
STOR /RS422 and RS485 Application Note.pdf
550 RS422 and RS485 Application Note.pdf: Cannot create file.
Failed [RS422 and RS485 Application Note.pdf: Cannot create file]
Hope it helps
S.N.A.P Protocol
We build an 485 Controller network, after reviewing some major leading industry protocols (such as CAN, TCP, PPP etc.), we found the SNAP as the perfect protocol to controller network. It is a very flexible protocol that can meet ALL MCU application needs from the very smaller resources and up to 16 bits controller end so no.
If you need any help, PM me.
yours,
Zohar
