active_si
Newbie level 2
I have the circuit as attached and the functionality is as follows:
- by default the relay is turned ON
- by default the LED doesn't light
when "CONTROL" is pulled down the LED lights up and the RELAY should turn off.
The problem that I have is that when I put some load on the place of relay the voltage drops quickly. For example if I put a LED instead of the relay the LED will light up but will graduately turn off very quickly.
What am I doing wrong?
thank you for any help resolving this
