user_asic
I've gotten in the habit of developing a lot testbenches and use for() and while() loops for testing purpose. Thats fine. The problem is that I've taken this habit over to coding for circuits which should be synthesizable. XST and others refuse to synthesize code (without additional modification to synthesis parameters) such as:
This is bad coding style because to the synthesizer test_num is an int with value 2^32! or it sees it as unbounded parameter. Either way, its a bad coding habit. But I'm so used to doing this in C and testbenches. What would be the equivalent synthesizable of code of the above code segment?
Thank you
while (num < test_number)
begin
num = num+1;
end
Thank you
