wood_girl
Junior Member level 1
- Joined
- Jun 13, 2008
- Messages
- 15
- Helped
- 2
- Reputation
- 4
- Reaction score
- 1
- Trophy points
- 1,283
- Location
- Bogotá, col
- Activity points
- 1,407
hi, i really appreciate your help, i have been working with an AD9834, it´s work fine at low frecuencies, but at highs the nominal 600mV start to fall. therefore at 30MHz the signal its only 70mV without any filter, i dont know what is the problem, maybe the capacitors?, the PCB?, the firmware??. any idea??...
the MCLK its 75Mhz
the control was made with a 18f2550 and SPI interface
the R is 6,8K
I removed form the PCB the extra capacitors of 0,1uF and the filter and the problem is the same...
pd: sorry for my bad english!!
the MCLK its 75Mhz
the R is 6,8K
