kvmanikandan
- Joined
- Aug 26, 2009
- Messages
- 53
- Helped
- 2
- Reputation
- 4
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- India,Hosur
- Activity points
- 1,632
Hi guys right now i am designing a PCB for high power load control Applications.
i have ipc-2221 standard for the track clearance.This standard only given the voltage rating .there is not mention the current rating that's why i am confused.
my design input is 12 volt 35 amps (time 1 minute) in a particular track.but i don't know the track clearance between the track also track width.
Board thickness is 1.6mm and copper plating thickness is 70 micron (2oz).solder mask layer also covered.
And one thing i am not a experienced pcb designer
So pls.. Any one suggest the track clearance and track width for the above requirement.
Thanks in advance.
MOD: this topic is moved from "Service Manuals, Requests, Repair Tips" section" with a warning to the member.
Thanks in advance.
