Rob B
Full Member level 4
max6952
As part of a project I need to develop a uC dot matrix display; there needs to be two rows of eight characters (5x7 arrays). Looking at the Maxim website I discovered the MAX6952 SPI display driver and thought that using four of them may reduce uC code and complicated multiplexing (maybe I'm making it more complicated?).
I will need to simulate the circuit (and hopefully the code depending on the simulation package) but I can't find any SPICE model for the MAX6952. I won't have much in the way of simulation to submit if I don't find a model to use.
I have access to Protel DXP 2004, OrCAD 10.5 and Proteus 6 which I would like to use for this if possible as it's quite a friendly program for simulating PICs. There is an extensive Maxim library bundled with Protel but the 6952 isn't there, the 7/8 segment LED driver chips are included though.
