How can I calculate dynamic power for an SRAM with Hspice?
reza1978
Newbie level 5
Newbie level 5
Hi all,
I designed an 32kb SRAM with its decoder, sense amplifier and .... and wrote its netlist with Hspice Now I want to calculate its dynamic power. I have some problems:
1- How should I calculate its dynamic power when the inputs are pulse?
2- Maybe one way is that I calculate the total capacitances in each node and use this formul: P=C×f×Vdd² but the problem is that when I use for example:
.PRINT CGG=LX18(OUT)
there isn´t any result in .LIS file or in .MT0 file,
so I can´t understand how I should calculate the capacitances in the transient mode.
3- When I put .OP in the netlist I saw total capacitances for all transistors but the problem is that they are for DC mode. Can I use these results for transient mode?
Thank you in advance,
Reza
Just run a reasonable number of cycles with reasonable
address / data activity, get to a charge-per-cycle value
from the supply current integrated over the run and the
number of cycles, and then you can interpolate / extrapolate
to whatever frequency.
Because many MOSFET capacitances vary w/ operating
point, you really want to get results from a full switching
analysis.
Hi, It means that I should calculate total Q for each node and then caiculat ethe dynamic power?
I'd just look at the current in your VDD supply (or supplies
if you have a mixed core / I/O scheme). Summing up all
of the individual nodes is doing it the hard way (and the
current in VDD, averaged, is already giving you the rollup).
Re: How can I calculate dynamic power for an SRAM with Hspic
hi frnd can i see ur schematic den i only i will be able to help.
hi dere reza1978, can i see ur SRAM schemtic, i can help u
Added after 0 seconds:
hi dere reza1978, can i see ur schematic, i can help u.
Reactions: malaee
    malaee
