simple FET Question- help needed
hemant03
Junior Member level 1
FET Question
I am using an N channel enhancement FET in my circuitry to ensure that I block positive voltages and allow negative voltages. I have tried to simulate the following circuit (attached). The Vgs(th) is 4V (for IRFL104). I am able to see an output voltage on drain eventhough the Vgs(th) is -5V (as gate is grounded). I am unable to understand the reason for that?
Thanks,
- Hemant
Re: FET Question
Check how the IRFL104 has been made up.
Re: FET Question
Firstly, what's VGG?
Also, do remember that the FET has a body diode across drain-source in reverse.
    hemant03
Re: FET Question
Vgg is the output. Basically my intention is to see V1 = Vgg when V1 is negative and no voltage when V1 is positive. I am trying to use the Vgs(th) concept and for an enhancement mode , Vgs is anywhere around 1 to 4 V depending on the type of FET. My problem is when Vgs is negative (as Vg is 0 and Vs is 4), I am still seeing V1 = Vgg when the FET should actually be OFF.
Thanks,
- Hemant
FET Question
Hi.
Thats because of the body diode as mentioned by Checkmate.
FET Question
Yes. Knowing how to draw simulations schematics in LTSpice is fine. Reading datasheets or text books is useful, too.
Re: FET Question
You may want to download an evaluation circuit and have a look how they have "designed" an N channel enhancement FET.
