can't get chipscope to work.
laserbeak43
Maryland, USA
I'm using Chipscope and the ISE 10.1 suite and i can't get it to work.
ERROR:ChipScope: One or more invalid signal connections detected.
ERROR:ChipScope: Double-click the scope.cdc icon in the sources window to edit and fix the CDC project.
ERROR: Chipscope Insertion failed
I'm using some very simple code
module two_input_xor (
	input wire in1,
	input wire in2,
	output wire out
	assign out = in1 ^ in2;
endmodule
and this doesn't even work. I've read xilinx's chipscope doc and decyphered what i could, but it still left me googling for tutos and i still get the same results after reading this one **broken link removed**
can someone please help?
HI
this message comes when all signals are not assigned clock and triggers properly...
if u run your .cdc files,the unconnected signals highlights in red color check out...
y
i hope this helps u...
The fact that the "very simple code" hasn't a clock may be reason enough for failure. You should try with a
somewhat elaborated code, e.g. a counter.
Hi
thanks for the reply, I kind of gave up on chipscope. seems like just another xilinx headache. but you've inspired me to keep trying.
This is my new module and it synthesizes with no errors
module clockedSwitches(input clk0,
							input [3:0] SW,
							output [3:0] LEDR
	parameter ms5 = 18'd250000;
	reg [17:0] cnt;
	reg [3:0] LED;
	always @(posedge clk0)
	begin
		if(|cnt) cnt <= cnt-1;
		else
			begin
				cnt <= ms5;
				LED <= SW;
			end
	end
	assign LEDR = LED;
endmodule
This Picture shows that my connections are good.
i click Analyze Design Using Chipscope and I get these warnings during implementations and Program file generation processes
WARNING:par:288 - The signal U_ila_pro_0/U0/I_NO_D.U_ILA/U_STAT/iSTAT<11>_wg_lut<7> has no load. PAR will not attempt
WARNING:Route:455 - CLK Net:icon_control0<0> may have excessive skew because
WARNING:par:283 - There are 1 loadless signals in this design. This design will cause Bitgen to issue DRC warnings.
WARNING:physDesignRules:367 - The signal
and this is what happens when chipscope is started
1st, everything SEEMS good
but when i configure i get this error:
can someone please help? I just ordered a crap load of peripherals for my board too. It kind of stinks...
Can you show us the full code where the ila and the icon blocks are instantiated along with your functional code?
r.b.
that is the full code. i just tried to make something that chipscope could use.
You need to generate ILA and ICON Verilog or VHDL blocks using Coregen and then build these into your project as well as your functional code.
Chipscope requires these blocks, as they sample the signals you are interested in and send the data to the Chipscope software.
r.b.
i used the inserter. as i was told that was the only method i needed to use. are you sure i need to generate cores?
The only way I have ever done it is to instantiate the ILA and ICON cores in my code. The inserter has never worked well for me.
