Naveed Ahmed
Member level 4
Hello dears!
I have designed Energy meter using ATMEGA32 MCU. For powering it, i have used separate power supply. When power is loss, MCU is turned off and all parameters are erased.
So, i have used a separate battery, which is used incase of power failure. The switching between power supply and battery is done using 5 pin SPDT relay using following config...
NO------Power supply
NC------Battery
C--------Output given to my circuit
When power is switched from battery to power supply, there is no problem . But when power is switched from power supply to the battery then MCU restarts, and all the static RAM parameters are lost
my circuit current consumption is 300mA at 5V.
I think i have to use Farad capacitor. so that it can maintain power for some time when relay switches???
I have 1F capacitor (5.5V) available at market.
Thank you...
Suggestions and ideas plz...........
Naveed Khowaja
NC------Battery
Thank you...
Naveed Khowaja
