frs89
Newbie level 5
Hi
I'm learning BJT's, I have a beginner's doubt.
The collector current in active mode is usually bigger or lower than when in saturation mode? I look in a ic-Vce plot that ic grows with Vce and drops when Vce-->0 i.e the CBJ is forward biased.
In an example that I looked on Sedra is said that the ic current is aprox 4.3mA, then because the max current in active mode is aprox 0.5mA the Bjt is clearly in the saturation mode. Please I need some clarification.
