Zangetsu57
Member level 4
pmc hfss
Hello everyone,
I am simulating a patch antenna that has H-plane symmetry. It is operating in the lowest mode. I get excellent impedance matching results for S11, but my radiation pattern (co-pol and x-pol) for both principal planes is not accurate when compared to the antenna simulated without the symmetry plane. Does anyone know why this might be? Is there something I need to do to tell HFSS to properly calculate the radiation pattern when using a symmetry plane?
Alternatively, if someone could link me or upload an example or tutorial as to how I should properly set up a symmetry plane, it would be greatly appreciated. Note that I DID use the impedance multiplier of 0.5 and set the port to solve Zpv.
Thank you in advance!
Hello everyone,
