What is MIMO channel? MATLAB question
mazdaspring
Full Member level 1
I know what MIMO is. It is something that uses multiple input and multiple output in the system.
However I am not clear what MIMO channel is. When I look for matlab code and see "mimo channel" code, Does it mean....that channel using Space time block coding/spatial multiplexing in the code or what?
Re: What is MIMO channel?
I have attached a .PPT , may be become helpful for you to understand the system MIMO concept and it's use in M2M Technology ......:D
Hi, Thank you for your file. Do you have mtlab code for it?
And Can you answer my another question if you can please..
When you talk about mimo channel do you mean that you apply Space time block code or spatial multiplexing in the channel?
Thank you so much for your helps. I am so happy you answered.
I will have a read through your file and let you know how it goes.
Anyway, I wish you have a wonderful year too (quite early to say :) )
hey my project is "Improve data rate using spatial multiplexing in MIMO as per IEEE 802.11n standard."
do u help me......????
i need a code...
help me fast
