design a rectangular patch antenna at 2.4GHz
chanzg
Junior Member level 3
Singapore
Patch Antenna
Hi All,
I wanted to design a rectangular patch antenna at 2.4GHz circular polarized using ADS momentum. I am new to this topic and hope to get some help.
1) Firstly, i try to find the L and W using the equation found in the textbk by Balanis. How can i determine the feed location if i want to use a probe fed. Can i find this L, W and feed location using the software
2)Is it that truncating diagonal sides of the rectangular patch antenna will allow me to get the circular polarised? How can i know know how much to truncated?
3)What else should i do to design the patch antenna before i can stimulate it?
Thank you in advance for any help. will appreciate if anyone could send me any infomation or tutorial on ADS and Patch Antenna design.
Re: Patch Antenna
chanzg said:
Hi All,
ref this www.rfic.co.uk
Reactions: valdrin
    chanzg
    valdrin
Re: Patch Antenna
Thank you sundarmeenakshi, this website is of great help. I have read through the part on patch antenna.
I have some questions,,
1)In the example given, the probe position is calculated to be 21 mm. Where is this 21 mm? Is from the ground to the patch? and where should it be located on the patch?
2) How can i truncated the rectangular patch so that it is circular polarised?
Thank you.
Re: Patch Antenna
Thank you.
thats not from the ground. that is from one corner of patch
Re: Patch Antenna
Then how to measure the 21 mm? Is 21 left, right up or down? Or we have to trial and error?
Re: Patch Antenna
down
Re: Patch Antenna
Sorry. I am still a bit unsure about the probe position. Refer to diagram.
