Mkanimozhi
Full Member level 4
Hi Experts,
When i synthesis one of my module in xilinx, i am getting this error , i don't know how to resolve this ,any one help me.
This is my Code
`include "rVEX_pkg.v"
//use work.ctrl_operations.all;
module c(clk,reset,opcode,pc,lr,sp,offset,br,in_valid,pc_goto,result,out_valid);
input clk; // system clock
input reset; // system reset
input [6:0] opcode; // CTRL opcode
input [(`ADDR_WIDTH - 1) : 0] pc; // current program counter
input [31:0] lr; // current link register ($r0.63) contents
input [31:0] sp; // current stack pointer ($r0.1) contents
input [(`BROFF_WIDTH - 1) : 0]offset; // branch offset (imm or lr) value
input br; // branch register contents
input in_valid; // '1' input is valud
output wire [(`ADDR_WIDTH - 1) : 0] pc_goto; // address to jump to
output wire [31:0] result; // new lr or sp value
output reg out_valid; // '1' output is valid
reg [31:0] result_i;
reg [(`ADDR_WIDTH - 1) : 0]pc_goto_i ;
assign result = result_i;
assign pc_goto = pc_goto_i;
function [(`BROFF_WIDTH - 1) : 0] f_GOTO;
input [(`BROFF_WIDTH - 1) : 0] offset;
begin
f_GOTO=offset[(`ADDR_WIDTH - 1) : 0];
end
endfunction
function [31:0] f_IGOTO;
input [31:0] lr;
begin
f_IGOTO=lr[(`ADDR_WIDTH - 1) : 0];
end
endfunction
task f_CALL;
output [(`ADDR_WIDTH - 1) : 0] pc_goto;
output [31:0] result;
reg [31:0] pc_tmp;
begin
pc_tmp[(`ADDR_WIDTH - 1) : 0] = pc;
pc_goto = offset[(`ADDR_WIDTH - 1) : 0];
result = pc_tmp + 1;
end
endtask
task f_ICALL;
input [31:0] lr;
reg [31:0] pc_tmp;
begin
pc_goto = lr[(`ADDR_WIDTH - 1) : 0];
end
endtask
function [(`ADDR_WIDTH - 1) : 0] f_BR;
input br;
begin
if (br ==1'b1)
f_BR= offset[(`ADDR_WIDTH - 1) : 0];
else
f_BR=(pc + 1);
end
endfunction
function [(`ADDR_WIDTH - 1) : 0] f_BRF;
input [(`BROFF_WIDTH - 1) : 0 ] offset;
input br;
begin
if (br ==1'b0)
f_BRF= offset[(`ADDR_WIDTH - 1) : 0];
else
f_BRF= (pc + 1);
end
endfunction
task f_RETURN;
input [31:0] lr;
input [31:0] sp;
begin
result = sp + offset;
end
endtask
// Controls CTRL operations
always @(posedge clk or posedge reset)
begin
if (reset) begin
out_valid = 1'b0;
result_i =32'b0;
pc_goto_i = {`ADDR_WIDTH{1'b0}}; end
else begin
if (in_valid) begin
out_valid = 1'b1; // this will be overriden a non-existent opcode is issued
case (opcode)
`CTRL_GOTO :
pc_goto_i = f_GOTO (offset);
`CTRL_IGOTO :
pc_goto_i = f_IGOTO (lr);
`CTRL_CALL :
f_CALL (offset, pc, pc_goto_i, result_i);
`CTRL_ICALL :
f_ICALL (lr, pc, pc_goto_i, result_i);
`CTRL_BR :
pc_goto_i = f_BR (offset, pc, br);
`CTRL_BRF :
pc_goto_i = f_BRF (offset, pc, br);
`CTRL_RETURN :
f_RETURN (offset, lr, sp, pc_goto_i, result_i);
`CTRL_RFI :
`CTRL_XNOP :
`NOP :
default:
out_valid = 1'b0;
endcase end
else
out_valid =1'b0;
end
end
endmodule
my error
ERROR:Xst:1706 - Unit <c>: port <result_i_concat0000<31>> of logic node <result_i_mux0002<31>> has no source
ERROR:Xst:1706 - Unit <c>: port <result_i_concat0000<30>> of logic node <result_i_mux0002<30>> has no source
ERROR:Xst:1706 - Unit <c>: port <result_i_concat0000<29>> of logic node <result_i_mux0002<29>> has no source
ERROR:Xst:1706 - Unit <c>: port <result_i_concat0000<28>> of logic node <result_i_mux0002<28>> has no source
ERROR:Xst:1706 - Unit <c>: port <result_i_concat0000<27>> of logic node <result_i_mux0002<27>> has no source
ERROR:Xst:1706 - Unit <c>: port <result_i_concat0000<26>> of logic node <result_i_mux0002<26>> has no source
ERROR:Xst:1706 - Unit <c>: port <result_i_concat0000<25>> of logic node <result_i_mux0002<25>> has no source
ERROR:Xst:1706 - Unit <c>: port <result_i_concat0000<24>> of logic node <result_i_mux0002<24>> has no source
ERROR:Xst:1706 - Unit <c>: port <result_i_concat0000<23>> of logic node <result_i_mux0002<23>> has no source
ERROR:Xst:1706 - Unit <c>: port <result_i_concat0000<22>> of logic node <result_i_mux0002<22>> has no source
ERROR:Xst:1706 - Unit <c>: port <result_i_concat0000<21>> of logic node <result_i_mux0002<21>> has no source
ERROR:Xst:1706 - Unit <c>: port <result_i_concat0000<20>> of logic node <result_i_mux0002<20>> has no source
ERROR:Xst:1706 - Unit <c>: port <result_i_concat0000<19>> of logic node <result_i_mux0002<19>> has no source
ERROR:Xst:1706 - Unit <c>: port <result_i_concat0000<18>> of logic node <result_i_mux0002<18>> has no source
ERROR:Xst:1706 - Unit <c>: port <result_i_concat0000<17>> of logic node <result_i_mux0002<17>> has no source
ERROR:Xst:1706 - Unit <c>: port <result_i_concat0000<16>> of logic node <result_i_mux0002<16>> has no source
ERROR:Xst:1706 - Unit <c>: port <result_i_concat0000<15>> of logic node <result_i_mux0002<15>> has no source
ERROR:Xst:1706 - Unit <c>: port <result_i_concat0000<14>> of logic node <result_i_mux0002<14>> has no source
ERROR:Xst:1706 - Unit <c>: port <result_i_concat0000<13>> of logic node <result_i_mux0002<13>> has no source
ERROR:Xst:1706 - Unit <c>: port <result_i_concat0000<12>> of logic node <result_i_mux0002<12>> has no source
ERROR:Xst:1706 - Unit <c>: port <result_i_concat0000<11>> of logic node <result_i_mux0002<11>> has no source
ERROR:Xst:1706 - Unit <c>: port <result_i_concat0000<10>> of logic node <result_i_mux0002<10>> has no source
ERROR:Xst:1706 - Unit <c>: port <result_i_concat0000<9>> of logic node <result_i_mux0002<9>> has no source
ERROR:Xst:1706 - Unit <c>: port <result_i_concat0000<8>> of logic node <result_i_mux0002<8>> has no source
ERROR:Xst:1847 - Design checking failed
actually result_i is a 32 bit reg in my module.
--Kanimozhi.M
This is my Code
begin
end
endfunction
input [31:0] lr;
begin
end
endfunction
task f_CALL;
reg [31:0] pc_tmp;
begin
end
endtask
task f_ICALL;
input [31:0] lr;
reg [31:0] pc_tmp;
begin
end
endtask
input br;
begin
if (br ==1'b1)
else
f_BR=(pc + 1);
end
endfunction
input br;
begin
if (br ==1'b0)
else
f_BRF= (pc + 1);
end
endfunction
task f_RETURN;
input [31:0] lr;
input [31:0] sp;
begin
end
endtask
begin
if (reset) begin
out_valid = 1'b0;
result_i =32'b0;
else begin
if (in_valid) begin
case (opcode)
`CTRL_GOTO :
`CTRL_IGOTO :
`CTRL_CALL :
`CTRL_ICALL :
`CTRL_BR :
`CTRL_BRF :
`CTRL_RETURN :
`CTRL_RFI :
`CTRL_XNOP :
`NOP :
default:
out_valid = 1'b0;
endcase end
else
out_valid =1'b0;
end
end
endmodule
my error
--Kanimozhi.M
