EUverNE
Newbie level 5
up down counter.v
Hi all,
I'm new in learning digital design for FPGA using Verilog HDL and encounter some difficulties trying to experiment designing a simple up_down counter. While compiling the design, Quartus v.9 web edition reports too many warnings regarding "combinatinal loops..." and "latches inferred for reg [out]...", and the simulator stops, reporting "zero-time oscillation on node..."
The code is:
module up_down_counter (up, down, reset, out);
input up, down, reset;
output out;
wire up, down, reset;
reg [3:0] out ;
always @ (negedge up, negedge down, negedge reset) begin
if (!reset)
out <= 0;
else if (!up)
out <= out + 1'b1;
else if (!down)
out <= out - 1'b1;
else
out <= out;
end
endmodule
I can't see where is the problem, and why i got those warning & errors. The textbooks doesn't seem to help enough, so any help greatly appreciated.
Thanks in advance
Hi all,
The code is:
output out;
reg [3:0] out ;
if (!reset)
out <= 0;
else if (!up)
out <= out + 1'b1;
else if (!down)
out <= out - 1'b1;
else
out <= out;
end
endmodule
Thanks in advance
