Problem with USB CDC and a PIC18F4550 as a slave
grindylow
Newbie level 6
Newbie level 6
hello, I have been playing around with 18F4550 as a USB device using a modified CDC firmware. I recently needed to have another 18F4550 to be controlled as a slave device. The problem is whenever I send data to the slave, the master hangs up(the blinkusb status freezes). I interfaced it using USART then changed it to software UART then I2C and the same scenario goes on. Prior to this, I successfully managed to interface a sensor that outputs serial data, I did that using software UART(just Rx is used). Now I interfaced it using SPI and it doesn't freezes anymore but the slave still doesn't get any data. Can anyone give me a hand on this? I'm really stuck on this..
here is my master code, and it's within the ProcessIO() function:
if (getsUSBUSART(USB_Out_Buffer, 4))
      received_data0 = USB_Out_Buffer[0];
      received_data1 = USB_Out_Buffer[1];
      switch(received_data0)
       case 'T' :
         USB_In_Buffer[0] = 'X';
         if (mUSBUSARTIsTxTrfReady())
               putUSBUSART(USB_In_Buffer,1);
         break;
       case 'q' :
         mLED_3_Off();
         break;
       case 'Q' :
         mLED_3_On();
         break;
       case 'w' :
         mLED_4_Off();
         break;
       case 'W' :
         mLED_4_On();
         break;
       case '*' :
         servo='a';
         break;
       default  : break;
   if(servo=='a')
    OpenSPI(SPI_FOSC_4, MODE_11, SMPMID);
    PORTCbits.RC2=0;
    Delay10TCYx(5);
    WriteSPI(received_data1);
    Delay10TCYx(5);
    PORTCbits.RC2=1;
    CloseSPI();
    servo=0x00;
here is my slave code:
void main(void)
char master;
int addr, i;
TRISDbits.TRISD0=0;
LED=0;
 for(i=0;i<18;i++) {
 Delay10KTCYx(0);
 for(i=0;i<7;i++) {
 Delay1KTCYx(0);
 for(i=0;i<5;i++) {
 Delay100TCYx(0);
while(1)
LED=1;
OpenSPI(SLV_SSON, MODE_11, SMPMID);
if(DataRdySPI())
	master = ReadSPI();
CloseSPI();
switch(master)
	case '1':
		LED=0;
		for(i=0;i<18;i++) {
		Delay10KTCYx(0);
		for(i=0;i<7;i++) {
		Delay1KTCYx(0);
		for(i=0;i<5;i++) {
		Delay100TCYx(0);
	break;
	case '2':
		LED=1;
		for(i=0;i<18;i++) {
		Delay10KTCYx(0);
		for(i=0;i<7;i++) {
		Delay1KTCYx(0);
		for(i=0;i<5;i++) {
		Delay100TCYx(0);
	break;
        default: break;
both pics are 18F4550 running at 48MHz
putusbusart
Not sure what you want. Are you trying to use a 18F4550 as a USB master?
basically yes. I have 18f4550 as master connected via USB, and a slave 18f4550 connected to the master
putusbusart function makes the usb hang
mmmm why do you open and close your SPI all the time?, you must open your SPI once during initialization, and U can change during execution... but openning and closing? even then... WHY don't you wait to finnish SPI communication????(in SPI master..) does WriteSPI function waits until all data is sended??? I don't think so, please check that...
    grindylow
openspi 1
There is no function to check if the SPI has finished sending that is why I used some delay but I'll consider your suggestions.
blueroomelectronics said:
I'm not sure I understand what your doing, the 18F4550 cannot be a USB host only a slave.
I don't think you really understand it. I have successfully used 18F4550 as USB device and now I want to add a second 18F4550 as a slave to the first.
Re: USB CDC and a slave
I have worked it out! Thanks Kurenai_ryu! Your suggestion definitely made it. I have stopped opening and closing the SPI all the time, and increased the delay. I should not forget those simple stuffs from now on. Here's the modified code:
Master:
void UserInit(void)
    	mInitAllLEDs();
	mInitSensor();
	TRISCbits.TRISC2=0;
	PORTCbits.RC2=1;
if(servo=='a')
	 PORTCbits.RC2=0;
	 Delay10TCYx(5);
	 Delay10TCYx(50);
	 PORTCbits.RC2=1;
	 servo=0x00;
Slave:
void main(void)
char master;
int addr, i;
TRISDbits.TRISD0=0;
LED=0;
 for(i=0;i<18;i++) {
 Delay10KTCYx(0);
 for(i=0;i<7;i++) {
 Delay1KTCYx(0);
 for(i=0;i<5;i++) {
 Delay100TCYx(0);
while(1)
LED=1;
if(DataRdySPI())
	master = ReadSPI();
switch(master)
