RTD interface circuit
BABESH
Full Member level 2
Full Member level 2
rtd circuit
I have Pt-100
I need circuit whose resolution is 1mv change for 0.1 Degree C change.
Presently i am working with ckt whose resolution is 0.03mV for 0.1 DegreeC,
But i don't want to operate in that region.
Any circuits of such kind?
tks
rtd interface
Take a look at the attached picture ..
If you need 1mV per 0.1° output change 49.99kΩ resistor to ≈250kΩ - this will set the gain to 26 - and the output of this amplifier will produce 1mV for every 0.1° ..
Regards,
IanP
rtd interface circuit
hello ianP
tks for ckt,
but i have a doubt about internal offset of op-amp,
will this ckt have this compensation?
any way i will try this on bread board.
Tks
--babesh :D
circuit rtd
Hi
I was facing the same problem few months ago.
I got a circuit which will give 20 mv for 0.1 C change. It was consisting of IA, OPmp and Active LPF.
I can't email it to u. but I could help u in imlemting your own :)
Added after 6 minutes:
IA : instrumentation amplifier
Opamp was used to adjust offset and final gain adjust.
Active LPF : was to eleminate supply noise due to Full/half wave rectifier.
Also there were current sourse that was used to fed the sensor with refrence current
interface circuit
Hi Babesh..
Did u get the output from above ckt????
I tried ckt on bread board as well as with simulation but it doesn`t work...
If you have any circuit for PT100 interfacing..can u post it here????
Thanks...
current source circuits for rtd
Hi vipul,
I did this without using current source.
My circuit is just one non-inverting configuration.
with +Ve fed with 500mV Vref, Rf=100Ohms,
R1=pT100.
It worked fine....
Babesh.
interfacing to 1mv pic
Hi Babesh,
Thanks for reply...
Actually I also get output of circuit with some changes...
Thanks,
Vipul
Can you give me circuit idea that convert 0.1 centigrade to 10 mV?
Reply me Soon
Regards,
Mitul Shinde
