Decesicum
tem cell
hello,
i have designed simple tem cell (metalic, air filled and a thin inner septum). I want to get field distribution inside the cell, but I don`t get expected results at all. I define a discret port (between the septum and the case) to feed it and the other end of the cell is left opened (I tried also to place a discrete port there) When starting solver, I get reflection coefficient s11=1, so no field in the cell. What is it wrong defined/set?
Thanks in advance for answering me![/img]
hello,
