how to plot gain, antenna impedance against frequency in CST
micropop
Newbie level 1
Newbie level 1
help on cst
I am currently starting using CST now, anyone knows how to plot gain and antenna impedance against frequency in CST? I appreciate any help.
Re: Need help in CST
From filed monitor u can set farfield button for a paticular frequency then simulate the design and the result will be in far field folder
Need help in CST
hi micropop,
Another easy way to learn is to analyse the examples given in cst. Open an example and it explains you what results they are simulating and by checking the setting you can understand the working of CST.
Praful
The only way I did it was tedious and slow. You can simulate and use the farfield simulations at different frequencies. Then there are some built-in macros to make plots from parameters at different frequencies.
    V
