information about commands required for lcd 16 by 1
jpkalsi
Newbie level 2
Newbie level 2
INDIA
lcd 16x1
i want know about all commands for lcd 16x1
16x1 lcd
most important to know: which LCD controller?
16x1 lcd commands
i have used 8051 microcontroller. actually there is a problem that the lcd is displaying only left 8 char. the next one's are not displayed
. if you know about it please tell me soon.
thanks.
lcd command 0xc3
The question was about the LCD controller respectively display manufacturer and type, not your microprocessor.
As mentioned in a recent same topic thread and various other edaboard contributions, 16x1 is often configured as 2x8. You'll easily find out by playing around with initialization code and character addresses.
16x1 display addresses
LCD interfacing 16x2 or 16x 1 or 20 x 4 is all same.
Mostly your LCD is compatible with lampex LCDs
See this page **broken link removed**
see if this helps you anyway.
lcd 16x1 8051
in 16x1 lcd
data address is as follows
00 01 02 03 04 05 06 07 40 41 42 43 44 45 46 47 in hex
next eight character has starting address of 40 as opposed to 16x2 lcd in which 40 is for next line
lcd type 16x1
refer to mazidi book
there they have written everything about lcd commands
I am sure thats enough for you
Thanks,
Rushikesh
www.projectsof8051.com
Reactions: Aaron2
    Aaron2
lcd 16x1 controllers
the display addresses are goes in the following ways in the LCD controllers
for 16x1
0x80 0x81 0x82 0x83 0x84 0x85 0x86 0x87 0xC0 0xC1 0xC2 0xC3 0xC4 0xC5 0xC6 0xC7
for 16x2
0x80 0x81 0x82 0x83 0x84 ... 0x8D 0x8E 0x8F
0xC0 0xC1 0xC2 0xC3 0xC4 ... 0xCD 0xCE 0xCF
so you have to change the addresses of the data displayed in case for 16x1 to display the rest of the 8 chracters
lcd 16x1
talking about commands, is there any difference between 16x1 and 16x2 ?
initializing code 16x1 lcd
no there is no difference in the commands
only the display is the difference
Re: lcd 16x1
all commands are same except addressing
for 16x1 you have to use addresses starting from 80h
and for 16x2 => for first line 80h and for second line C0h
rest all is same
