pokemonstation
Junior Member level 1
calibre lvs
Hello all,
I am having trouble with Calibre LVS. My problem is that Calibre LVS does not recognize the pins I placed in the layout. For example, in an inverter my schematic has 4 ports (in, out, vdd!, gnd!) but Calibre LVS states that my layout has 0 port, despite I labeled all 4 ports in the layout. I have tried to use Create -> Pin or Create -> Label to label pins in my layout, but none of them works. Does anyone know what I should do to label pins in my layout so they are recognized by Calibre LVS?
My second problem is with Calibre extraction (PEX). I was able to extract a netlist with parasitic capacitance and resistance, but the pins/nets in the resulting netlist are not labeled as I wanted in my schematic, despite I specifically set the extraction option to use schematic nets. Does anyone know a solution to this? Do I have to have a successful and error-free LVS run in order for this to work?
Thanks in advanced!
Hello all,
Thanks in advanced!
