i need Schematic diagrams for modulation types(donation)
Aya2002
Iraq
need for modulation
hi friends,
i need a Schematic diagrams for the following modulation types (i will donate 5 points for each diagram):
1. amplitude modulation (all its types)
2. frequency modulation
3. phase modulation
4. ASK modulation
5. PSK modulation
6. FSK modulation
i need them using the OP-AMP
Many thanks
amplitude modulation circuit diagram
the schematics for the AM transmitter and receiver is shown below.
I hope u what u wanted.
all d best
    Aya2002
simple am transmitter schematic
The schematics for the FM transmitter and receiver is shown below.
    Aya2002
amplitude modulation schematic
below is the circuit diagram for SSB AM transceiver. The circuit diagram consists of 2 parts.
    Aya2002
Below is the circuit diagram for the DSBSC modulator Circuit which uses the Balanced modulator IC LM1496.
Hope u got what u were looking for...
    Aya2002
schematic modulator fsk
Thank you my friend but i need them all using the op-amp with a simple explanation
for each circuit
Reactions: ksy
    ksy
whats the need of modulation
this is to be simple to build in the laboratory for the students as well as the analysis and all the calculations will be simple and very clear
what is modulation with diagram
any help please?
balanced modulator circuit diagram
no 1 can help me?
transmitter modulation circuit diagram
I managed to get these schematics of AM using op amps.check them out!
Hope you got what u were looking for.
Reactions: larsendj
    Aya2002
    larsendj
amplitude modulation with diagram
Here s the schematic for FM TX. given below is the circuit description.
Parts List:
R1 4K7 R4 150K R7 3K9 (2K7)
R2 4K7 R5 220R R8 120R (82R)
R3 4K7 R6 4K7
All resistors except R8 are at least 0.25W rated. R8 is at least 0.5W rated
(the 0.6W metal film M-series from Maplin can be used for R1-R8).
C1 1n C4 22uF C7 10n C10 1n
C2 4u7 C5 1n C8 1n
C3 1n C6 10n C9 33pF
VC1 5-60pF IC1 LM358 Q1 ZTX108
    Aya2002
i do not know the second circuit, can you explain it please as it is not clear for me as a parts
Added after 3 minutes:
thanks
