altera VS Xilinx modification needed to apply code to altera
hayaloo
Newbie level 5
altera VS Xilinx
Hi guys
im doing a project on vhdl that ias IMA_ADPCM compression method usimg VHDL .
there is a code for this algorithm on web but this code uses Xilinx ISE 9.2i tool and i have to use Modelsim Altera web edition .
does anyone can tell me what exactly are diffrences between these to tools , i mean what modifications must be made untill this code can be applied on altera ?
thanks for you time
@ltera VS Xilinx
Xilinx ISE 9.2i is used for synthesis.
Modelsim @ltera web edition is a simulator which is having the libraries supported by altera vendor...
if your design is dependent of the xilinx vendor u hav to replace the functionalities of those modules..
ex:- if memory is generated by IP coregenerator(xilinx) u have to replace the memory module using megawizard plug in manager(altera).
    hayaloo
@ltera VS Xilinx
Am not able to reply in PM am replying here..
"what is the acutal diffrence between the code that one may write for simulation and code for synthesis ?"
There is no difference between synthesis and simulation code for RTL, whatever u r coding should be synthesizable. In test bench(TB) u can include the not synthesizable code like wait statement. Bcoz TB is not used for synthesize.
The codes are not different for different tools..
The code has to follow the verilog or VHDL standard.. Usually if u written any non-synthesizable code Modelsim simulator will show warnings. If it is wrt TB file u can safely ignore the warning. If it is wrt RTL then u must remove the warnings.
Tools used in Altera for synthesis is quartus II..
U can download this in altera website.. for web edition no license is required.
Latest quarus version is 9.0
Hope this may helps u..
If u hav further queries / or this info is not clear please send me message.
Best Regards,
Shanmugavel D
    hayaloo
Dear hayaloo
This is right that "The codes are not different for different tools".But the way that different tools synthesize the codes are not the same.some codes may be synthesizable in ISE but not in Quartus and viceversa.
The best solution is that you compile your code in Altera Quartus and then follow messages and warnings and then make changes and modifications to your program.
best regards
I assume that you are asking for IMA ADPCM Sound Encoder :: Overview :: OpenCores
you should provide a link instead of making us search.
I have downloaded the code and tried it in Quartus II (cycloneII), it compiles and fits fine but i don't know if any functionality is lost,
i have attached the log from QuartusII
Alex
P.S. I just noticed that this thread is almost 2 years old,
I just saw the previous answer that was new.
  • messages.zip
