operational amplifier VS. cascode operational amplifier
masa_2010
Newbie level 6
Newbie level 6
I need someone to tell me the main advantages of cascode op amp over the conventional op amp ?
1) cascode opamp has a better output impedance than a normal opamp. Hence higher gain.
2)Due to stacking cascode has lower swing.
3)Higher unity gain bandwidth than a conventional amp, as there is no miller effect in the input transistor.
hope it helps
    masa_2010
