HFSS : how to select excitation in far field for 2 port ant
nschutten
Member level 3
Member level 3
how to select two ports at a time in hfss
I am currently designing a two port (diversity) metal stamped antenna, using HFSS.
Simulating S-parameters is straight forward, and I can view a far field result, but I am not sure what excitation port (Waveport1 or Waveport2) this far field originates from.
Does anyone know how I can generate far field reports of my dual port antenna, first one with Waveport1 as excitation, then one with Waveport2 as excitation, so that I can also observe the difference in radiation pattern and hence the diversity gain?
Thanks in advance!
hfss far field
I have the same problem. Did you solve the problem?
hfss simulation two port excitation
No, unfortunately not.
In the mean time I have been using GEMS (from www.2comu.com) that is based on FDTD and does support explicit excitation definition. BTW, also Sonnet (MoM) support explicit excitation definition.
port excitation hfss
HFSS also supports explicit excitation. Just go to HFSS>Fields>Edit sources and change "scaling factor" and "offset phase" as required.
